Long end mill chatter
Discussion in 'CNC Mills/Routers' started by hosa200, Apr 27, 2018.
Tags:
  1. hosa200
    hosa200 New
    Hi, I am making a CNC router for Foam industry and of course I need to use long End mills and when I used a spindle like in openbuilds machine ,the end mill chatters and I guess the internal bearing was harmed somehow because it make noisy sound.
    So what is the solutions available to overcome such a problem.
  2. jeffmorris
    jeffmorris Journeyman
    Can you see if the bit "bends" while cutting? If so, the bit is too long. Slow down the feed rate. If possible, use heated foam cutter.
  3. Kevon Ritter
    Kevon Ritter Veteran
    A longer end mill only exaggerates imprecision in the router as well of flex in the gantry. How long of an end mill are we talking about here? Also what diameter? Are you using a spindle or are you using a router?
  4. hosa200
    hosa200 New
    Hi, Kevon, Thank you for your replay.
    I am using a 6mm end mill 15cm long and I used a router.
