Linear Stop
Discussion in 'Other Builds' started by Adam Filipowicz, Sep 18, 2015.
  1. Adam Filipowicz
    Adam Filipowicz Journeyman
    I am interested in making a Linear Stop using Openbuilds
    something similar to this
    http://rexelpoland.com/en/catalog/view/9/3/manual-length-measuring-stop-pr-1
    I would like to be able to Set a Distance and have it move to that position. but also be able to move it manually by hand if needed and have it report back the current length.
    Any advise regarding getting a arduino or other controller to do this would be appreciated.
  3. Adam Filipowicz
    Thanks. Id rather not run it on a PC.. need to figure out a simple way to run it on with a keypad and small LCD
  4. Rick 2.0
  5. Adam Filipowicz
    do you need a motor encoder on a stepper. I thought it was already built in
  6. Rick 2.0
    Yes and no. Theoretically you can count steps but if you get it moving too fast it can lose track of them.
  7. Adam Filipowicz
  8. Joe Santarsiero
    Joe Santarsiero OB addict
  9. Adam Filipowicz
    So a Servo Motor would seem a better solution
  10. Joe Santarsiero
    I wouldn't say so. For this I think a servo is a bit overboard. I'm guessing speed isn't a concern, so a stepper is probably the most economic route. You could even throw in a homing routine. How long do want to make this?
  11. Adam Filipowicz
  12. Adam Filipowicz
    #12 Adam Filipowicz, Sep 19, 2015
  13. Adam Filipowicz
    ideally up to 96" but to make it easier. maxing out at 1500mm for now
  14. Joe Santarsiero
    Okay. What is this for?
  15. Adam Filipowicz
    Trying to make a Digital End Stop for cutting pieces to an exact length.
    like this http://proscale.com/products/woodworking_related/prostop2.htm
    but more automated. so i can set 10.4 inches and it will adjust to the exact spot needed
    so i can make accurate cuts.
    so it would likely be Arduino based, have a control keypad a simple LCD Display to show position
    I should also be able to slide it manually by hand without it loosing its position. thats why the servo or an encoded stepper
  16. TubbyMcFats
    looking for the same thing. can't seem to find a mechanism that allows for manual engagement/disengagement from the lead screw.
