Limit switch wire?
Discussion in 'General Talk' started by Tim Wiltse, Feb 20, 2018.
  1. Tim Wiltse
    I am finishing up a super sized Sphinx build and need to start setting up the limit switches. What type of wire do I need to run? Does it need to be shielded wire?
  2. Kevon Ritter
    Kevon Ritter Veteran
    The limits are possibly the most sensitive wiring on a build. The last thing you need is to be hours into a job for it to stop for a false limit trigger.
    I use 24awg shielded (wrapped strands). You only ground one end.
  3. Gooshpoo
    Gooshpoo Well-Known
  4. Giarc
    You can get shielded wire at Home Depot or Lowes a little cheaper if you have one nearby. I paid $0.22 per foot for shielded wire for my limit switches. You only have to buy what you need, too.
  5. Tim Wiltse
    Dang it! I have been to Lowe's 4 time today....no lie! Didn't even think to look for anything I could use there. I'll look tomorrow. Thanks for the headsup.
  6. Giarc
    I believe the brand is Southwire.
  7. Kevon Ritter
    Good call. I'll have to check next time.
