Lillte Routy With Issues
Discussion in 'CNC Mills/Routers' started by vjwelch83, Nov 1, 2015.
  1. vjwelch83
    vjwelch83 New
    I'm new here and I got my machine up and running. I am able to send gcode to and cut. I only have one slight problem. If I design a 10mm x 10mm square in artcam and then send the code over to cut it out the machine will cut a 20mm x 20mm square. Everything in the x and y axis is doubled.
    I also tried a couple of Z axis checks and it seem that is cuts shallower than programed to.
    Like I said in the beginning, I new to this. Where should I be making the adjustment to make it cut accurately?
  2. vjwelch83
    vjwelch83 New
    It was definitely a calibration issue. 5 mins after I wrote that I figured it out. I just had to go in in correct some numbers. Thanks for the quick reply though.
