Learning how to build
Discussion in 'CNC Mills/Routers' started by Twoods, Jun 15, 2020.
  1. Twoods
    Twoods New
    Twoods published a new build:
  2. MaryD
    MaryD OpenBuilds Team
    Is that a plasma attachment I see?
  3. Twoods
    Twoods New
    Yup. I refit it to run a small plasma cutter as well as a router. All I did was link the torch to the z axis lower limit to fire the torch. Then all that was left was setting the pierce timing in the plasma software. And the proper... ( translate to gcode software I forgot what it's called. The offline controller doesn't do arcs ) and I was all set
    Giarc likes this.
