LEAD1515 linear bearing option?
Discussion in 'CNC Mills/Routers' started by Kyle Rausch, May 16, 2022.
  1. Kyle Rausch
    Was skimming through the different forums trying to see if this has been brought up for the 1515 but did not come across anything. Is there an option or a way to configure the LEAD1515 that would support the use of a linear rail bearing in place of the wheels? I am coming up to a point where I am looking at replacement with the wheels being worn down. I have done well keeping up with the adjusting of wheels as needed to make sure everything stays running smooth, but had the thought come in about making the switch if possible with the way the build is currently set up.
    Any thoughts, advice or if this has been done a chance to see it would be great!!!
  2. Alex Chambers
