Lead 1010 High Z Mod question
Discussion in 'CNC Mills/Routers' started by BeeAMaker, May 21, 2022.
  1. BeeAMaker
    BeeAMaker Well-Known
    Finally getting around to installing the High Z mod on my 1010, however I am not using it to gain Hight, I am adding it to gain stability. I will be cutting the unneeded length off. I know I saw this question come up before but now I can not find it.
    My question is, Any reason I can't keep the X lead screw on the bottom C-Beam vs the top? Some argue that it may be preferred. Also I would not need to extend my wires in the drag chain.
    Thanks -
  2. Giarc
    I believe mine is on the bottom on my lathe, which is basically a lead 1010 high z and with a rotary axis instead of a y axis.
  3. Rick 2.0
    Powering the bottom rail is definitely the way to go. It results in greater lateral stiffness making for a cleaner cut.
    BeeAMaker and Peter Van Der Walt like this.
