Kress1050/800fme Top Bracket Files
Discussion in 'CNC Mills/Routers' started by Jonny Norris, Jan 25, 2015.
  1. Jonny Norris
    Jonny Norris Well-Known
    Hello .. I had a bit of play in my kress bottom bracket, so if its any good to anyone, Thought id post the cad files to a top bracket i designed for my kress 1050 fme, although i believe it should work for the 800 fme also. (though it may be worth cutting a wood prototype before milling from ali) And you may want to check/change the dimension of the rear half of the bracket, depending on your ox.
    Zip here: (contains iges, step, and ipt files) http://jmp.sh/b/Vu0ClYF8J785pH46HQ15
    GrayUK likes this.
  2. Jonny Norris
    does indeed fit the 800fme :)
    sgspenceley and GrayUK like this.
  • About Us
    [email protected]
  • Follow us on Instagram
  • Like us on Facebook
    Donate to Open Source
