Hi all, I’m having a strange issue anytime I run probing routine. Using a black box with xyz plus. The probing routing works fine, but after it finishes, jogging is broken. After probing, the jogging buttons and the keyboard, behaves like a momentary switch. Meaning, if pressed quickly the head jogs a tiny amount. If held down, it jogs for a few inches then throws an error 15. I have to exit control and shut it down completely, after which it behaves correctly. Any suggestions, or is this a known issue? Thanks so much!
