Job Stops at Randomly
Discussion in 'Control Software' started by RAMoner, Dec 23, 2020.
  1. RAMoner
    RAMoner New
    I am getting this error randomly while running a job. GRBL file out of Vectric VCarve Pro. Ran this same toolpath and file several days ago without issue. Job will progress and then Machine/Controller THNIKS it hit a HARD LIMIT but job is 10"X10" and running in the middle of my LEAD 1010. I homed the Router and started Job over and got a little further, and then again, and then one more time before I decided to post.
    Only change was an update of the OPENBUILDS Controls software to 1.0.266 just yesterday. Any hints?
    I have check wiring and connections on all limit switches and nothing there?
    Here is the full chain of events
    [16:23:19] [ ALARM ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ G1X219.512Y166.384 ]
    [16:23:19] [ ] ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended. [ G1X219.512Y166.384 ]
    [16:23:19] [ G1X219.512Y166.384 ] ALARM:1
    [16:23:20] [ G1X219.512Y166.384 ] [MSG:Reset to continue]
    [16:23:20] [ G1X219.512Y166.384 ] ok
    [16:23:20] [ G1X219.879Y166.505 ] Grbl 1.1g ['$' for help]
    [16:23:20] [ G1X219.879Y166.505 ] [MSG:'$H'|'$X' to unlock]
    [16:23:20] [ ] error: 9 - G-code locked out during alarm or jog state [ G1X219.879Y166.505 ]<hr>This error may just be a symptom of an earlier event:<br> ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
    [16:23:20] [ ERROR ] error: 9 - G-code locked out during alarm or jog state [ G1X219.879Y166.505 ]
    [16:23:20] [ G1X219.879Y166.505 ] error:9
    [16:23:20] [ ] error: 9 - G-code locked out during alarm or jog state [ G1X220.805Y166.920 ]<hr>This error may just be a symptom of an earlier event:<br> ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
    [16:23:20] [ ERROR ] error: 9 - G-code locked out during alarm or jog state [ G1X220.805Y166.920 ]
    [16:23:20] [ G1X220.805Y166.920 ] error:9
    [16:23:20] [ ] error: 9 - G-code locked out during alarm or jog state [ G1X221.737Y167.470 ]<hr>This error may just be a symptom of an earlier event:<br> ALARM: 1 - Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
    [16:23:20] [ ERROR ] error: 9 - G-code locked out during alarm or jog state [ G1X221.737Y167.470 ]
    [16:23:20] [ G1X221.737Y167.470 ] error:9
    [16:23:39] [ ] Grbl 1.1g ['$' for help]
    [16:23:39] [ ] [MSG:'$H'|'$X' to unlock]
    [16:23:39] [ ] [MSG:Caution: Unlocked]
    [16:23:39] [ JOB COMPLETE ] Job completed in 00h 07m 06.5s
  3. RAMoner
    RAMoner New
    Thanks!
    Winter in North East Ohio, aka Dry Air ... I also ran an extra ground on the Vac Hose ... Thanks!
    Simple solutions to complex issues. Merry Christmas & Happy New Year!
  4. Giarc
    It is cold and dry here, as well. Yesterday I was doing a v-carve and luckily made it through the carve portion of the job. It was on the cutting out of the part that I got a "USB Error" and Estlcam stopped the job. Instead of the dust shoe, I was vacuuming by hand because I wanted to watch the carving process (first time V-caving with Estlcam). I got the hose right next to the USB cable and it threw the error. That was the first time in 5+ years I have owned this CNC router I have ever had an EMI issue. Lesson learned. :thumbsup:
  5. cnc0014
    cnc0014 New
    I'm in the same boat. Trying to figure out what is causing the issue. Live in a cold/dry climate. I am getting the machine setup so haven't really been cutting at any length but seeing if I have to tram the router so running a larger surfacing job. I get about 75% through and it throws the error. I just "upgraded" the dust collection and with the increased movement of air it must be building up more static.
