Issues turning spindle on in the Gcode
Discussion in 'CNC Mills/Routers' started by Pursl006, Feb 15, 2021.
  1. Pursl006
    Pursl006 New
    I have been having an issue with my Workbee where, despite putting M3 and M5 into my Gcode, I need to start and stop my router before running my code otherwise it doesn't turn on when the program is run. I have the black box connected to the IOT switching relay power and my router plugged into the normally off plug. I have had a few different tools plugged in this way. is there something else I need to add to my code or is turning the router on and off before running the only way to get it to trigger in the code?
    thanks
  2. Pursl006
    Pursl006 New
    I should mention that i turn it on and off through the Openbuild control drop downs.
    Did you forget the S-word?
    For example, if $3=1000, you want M3S1000
  4. Pursl006
    Pursl006 New
    Ahh, thanks. i am using a different cam software so i have to go in and add certain commands.
