is there something simple
Discussion in 'CAD' started by edward siegel, Apr 29, 2015.
  1. edward siegel
    is there a cad program that's easy to learn
    this stuff will make you pull your hair out im trying to draw a side and top profile of a 32 for frame I have a 30 x 40 blueprint with measurements in quarter scale im having no luck at all
    I tried libre cad now im ready to get drunk and call it a day grrrrrrrrrrr
    I just want to draw this and run it through cam so I can start cutting
  2. John Williams
    the one program I fell in love with was solidworks/cam. I also use inventor. I tried sketch up, however i do not like the interface for direct input of dimensions. i do not etch a sketch, i type my ccords directly. you could try freeCAD.
  3. John Meikrantz
    John Meikrantz Well-Known
    I finally wound up with ViaCad after similar struggles. It was the easiest for me to learn. I started with 2D and upgraded to the Pro version.
  4. edward siegel
    id love solid works but I don't have 3500.00 poor man budget here.
    ive never heard of via cad
    all I need it 2d for now im drawing flat plates to cut on a plasma table
    witch is giving me fits at the moment I cant get my proma thc to work properly it moves the z axis up and down in test mode but when I try to run a program it stops any movement its not rf either ive tryied it with out the plasma cutter on at first I thought here we go im buying a 2200 dollar hypertherm but I left off the plasma cutter
    and it still did it I have a software glitch somewhere ive tried allot od settings in mach3 but no luck yet
  5. Joe Santarsiero
    Joe Santarsiero OB addict
    Try Onshape.
    I think the easiest route for 2d work is just writing the G code myself. No cad/cam needed.
  6. Texflyboy
    Texflyboy New
    You might also consider Fusion 360. I find it to be very intuitive and much more capable than sketchup. You have a lot of control over your tool-paths if you want to tweak them. There is a free trial and after the trial you can continue to use it for free if you are not using it commercially.
    #6 Texflyboy, May 9, 2015
  7. Joe Santarsiero
    Fusion 360 is nice. I use it. I wouldnt consider it simple though.
  8. Ryan James
    I've been playing with Fusion 360 this weekend. Not a lot, just to get a slight feel for it. One thing I like about it over Sketchup (which I know fairly well) is the grid. If Sketchup has a grid, I haven't figured it out yet.
  9. Val Cocora
    Val Cocora Well-Known
    you might want to try autocad, it's intuitive and if you understand geometry, you're game. precision wise, goes up to 8 decimals, 16 internally. it's also preset for metric or imperial, so another bonus.
    last but not least, it exports directly to stl, no more hassle.
    have a beer and enjoy life while your solid file is woven on the screen.
  10. sw3Dp
    sw3Dp New
    Onshape or fusion360 are the best looking new free cad out there with the added benefit of progressive development but it means a bit more time in the youtube pits and hoping they come of age before they sell out like sketchup. That being said solid works and inventor are the best and easiest to learn for working with solids but they ain't free ... for long.
  11. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Absolutely excellent work Robert. :thumbsup:
    Tweakie.
  12. Jimmybuckets
    Jimmybuckets Well-Known
    I like MOI3D nurbs based. Moi3d.com
  13. Traxxtar
    Traxxtar New
    Trying to create text that follows a circular path in any program.... Is there a way to do that easily??
  14. Mark Carew
    You may want to give Inkscape a try
  15. Tweakie
    Moderator
    Perhaps also look at F-Engrave - free and extremely easy to use with the ability to import fonts etc.
    Tweakie.
  16. Traxxtar
    Traxxtar New
    I'm very surprised none of the CAD programs I've looked at have this ability native/built-in. It's a bit shocking really. The 'text' tools really need work in those programs.
    Thanks for the link, I'll take a look at Inkscape. I've seen it mentioned on many sites for various things, just never looked at it.
  17. Val Cocora
    I believe Autocad has a function to wrap text around an arc/path. In express tools, select arctext command
  18. Traxxtar
    Traxxtar New
    Is there a free version? ;)
  19. Val Cocora
    indeed, autocad is not free, unfortunately.
  20. Flash22
    Flash22 Well-Known
    fusion 360 can do text on any path - 360 does take time to learn but you can get some really complex shapes
    Fusion 360 is free for hobby use
    something I put together in 15 min or so
  21. Julius
    Julius Well-Known
    use the tape measure tool, or I think there is a plug in to create one. Rhino has a grid on at all times, I don't like it.
  22. Ryan James
    Just loaded a Grid extension from the Sketchup Team. It allows you to draw your own grid using guidelines. It's under tools so now I just have to figure out how to get it onto a toolbar. Seems to be OK. Have to play with it some more now.
  23. Julius
    Julius Well-Known
    Just make a grid as a compenent, and then save the blank grid as a new template, and you'll always open up to it for a new file, or can copy paste it into any current work.
