Is C Beam compatible with VSlot ?
Discussion in 'CNC Mills/Routers' started by MartinTurner, Nov 10, 2015.
  1. MartinTurner
    Hey There
    Can anyone tell me if it is possible to run wheels across an 80-20 Vslot bolted to a cBeam ?
    In the sketchup drawings provided by Openbuilds the lips of the slots look slightly different ?
    Also in sketchup the spacing looks slightly different as i go from one to the other hence the little gap between the spacer and the last wheel ?
    Martin
  2. MartinTurner
    That's good news..
    Is a little shim required in that last wheel ?
    According to sketchup there is not enough room for a washer, but there is still a little gap...
    Cheers for your help
    Martin
  3. Rick 2.0
    Don't put too much faith in the accuracy of the sketchup drawings. The only way to know for sure is to fit up actual pieces.
  4. Flash22
    Flash22 Well-Known
  5. MartinTurner
    Ahhh right got it.
    Sketchup is only accurate up to .1 of a mm.
    That explains that.
    Thanks Chaps
  6. Mark Carew
    "SketchUp's internal accuracy is 1/1000 of an inch (0.025400mm). If two points are closer than this distance they are considered the be at the same position.
    But the tolerance can be compounded due to combinations of transformations. So when you're using dimensions around 1mm and less you're entering the twilight zone."
    A trick is to build at a larger scale then scale down lower.
    You can also take a look that the SolidWorks Resource Models and drawings here: SW Parts Library
