Introducing PlusBot 3D Printer @Makemendel
Discussion in '3D printers' started by makemendel, Nov 29, 2014.
  1. makemendel
    PlusBot is a fully working 3D Printer with build size of (22 x 22 x 16.5) cm .
    PlusBot Features :
    - Highly Stable design
    - 100 micron print layer
    - 0.4 mm Nozzle Diameter
    - Smart LCD control support which allows SD Card Printing.
    - Can be controlled without a PC
    Technical Specifications :
    Machine Size : 450 x 350 x 370mm
    Build Size : (22 x 22 x 16.5) cm
    Nozzle Diameter : 0.4 mm
    Layer thickness : 0.1 mm
    Speed : 60 mm/s
    Positioning Precision : 27 micron
    Input format : STL
    Technology : FFF
    Software : Pronterface
    System Compatibility : Windows 8,Windows 7,Windows Vista,Linux
    Power Supply : 20 A SMPS Power Supply,250 W
    Weight : 12 Kg
    This is how the Printer Looks Like !!
    More about the PlusBot 3D Printer : http://makemendel.com/3d-printer/plusbot
    Looking Forward for your Views !!
