Interface probe and MM to inches
Discussion in 'Interfaces' started by bo Toepfer, May 18, 2022.
  1. bo Toepfer
    Hello I am using the OB interface control with my LEAD 1010, Can I change from MM to inches and how? I try to use the OB probe it tells me I do not have that utility? when I finish cutting the job I get a GRBL error any help please .
    Tools and Utils > Interface Settings > Units
    You mean error says Probe file not found? Remember to prepare the USB Drive: Section 3.3 of docs:interface:start [OpenBuilds Documentation]
    Grbl has around 40 different errors Grbl v1.1 Interface · gnea/grbl Wiki - please provide the exact wording for assistance
  3. bo Toepfer
    I have v 1.43 dated Jan 18 2021, I have dicovered more issues, when I hook the interface to the computer I get a Hi message and it reads Game over?
  4. bo Toepfer
    Check cable between Interface and BlackBox for damage, unseated connector pins, forgot to switch on BlackBox, forgot to unplug the USB cable, etc
    Then your GCODE contains invalid characters. Make sure you are using the correct CAM/Post Processor and also ensure it is up to date
    Update to v1.52 dated May 2022 please
  6. bo Toepfer
    Thanks Peter I will give it a try ! much appriciated
  7. bo Toepfer
    I think I was able to get through the update It now reads v 1.52 or 1,53, I can't remember, but it finished with a test of all interface control buttons, Thanks to all !
