Interface.. calibration
Discussion in 'CNC Mills/Routers' started by sjashe, Dec 8, 2021.
  1. sjashe
    sjashe New
    I am looking at updating/replacing the Z-axis
    I understand calibration in Control.. but does that automatically apply to the Interface? Or is that even an issue?
    Calibration is stored on the BlackBox (Grbl parameters are stored in EEPROM: Grbl v1.1 Configuration · gnea/grbl Wiki)
    Interface, CONTROL, any other Grbl host just fronts/controls Grbl running on the BlackBox
    So, after replacing your Z axis, just connect the Computer for a bit, use the Calibration Wizard to fix up your settings. Take a backup (since you are now running custom parameters) and put the PC away
  3. sjashe
    sjashe New
    Thanks.. I tend to jump back and forth between the computer and the Interface.. so didn't want to lose that capability.
  4. perks1018
    perks1018 New
    This thread is the closest to the problem Im having getting up and running with interface. I had intermittent success running off of a computer (Mac, not pc) with blackbox, but now with interface my problems have swapped. Now I can connect instantly to my recently upgraded 1510 Cbeam, and I can jog and zero to my hearts content, but I cannot run any gcode files. The second I try I get a grbl fault of one sort or another. It sounds like a calibration issue, but apparently I cannot do any sophisticated calibration in the edit GRBL function of the interface?
    Specifics are important - note the EXACT errors and we'll be able to tell you what causes them
  6. perks1018
    perks1018 New
    I was going to do a real short video (5-10 secs) of what is happening but as I set up, I noticed on the Interface DRO I am getting readouts that are at complete odds with the actual movements of the axes, for instance, 100s of millimeters for only an inch or so of actual movement. I think I need to go back to basics here and recalibrate the machine, the steps are clearly off. Is there a comprehensive video you could point me to? I selected Workbee 1510 as the Grbl profile and swapped axes because my X is the long axis. Im using optical endstops for limit switches and they all function correctly.
    See our YouTube channel
