Interesting approach to increasing 3D print size.
Discussion in 'Concepts and Ideas' started by Rick 2.0, Mar 3, 2015.
  1. Rick 2.0
    This just popped up on kickstarter. It uses a slightly modified Ultimaker mounted upside down on a vertical slide to increase Z axis length up to 3 meters.
    It may be a project worth supporting even if you don't have an Ultimaker as it is fairly certain someone (more likely a number of someones) here will be doing a V-slot based knockoff.
    The full story which can be found here provides a lot more detail including close-ups of the 30000 names embedded in wrinkles of the elephant's skin. There is also a short documentary video of the process that is well worth watching.
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    What a wonderful project and all for such a good cause. :thumbsup:
    Tweakie.
