I'm easily confused
Discussion in 'CNC Mills/Routers' started by GrayUK, Jul 10, 2014.
  1. GrayUK
    Hi Mark.
    Thanks for letting me know my order so far, is on its way. :thumbsup:
    Right then. Can you put me right with regard to the shims and the spacers? :confused:
    I held off ordering them before, because I knew there were going to be changes, but I see there are some in stock now.
    So, are these the new ones, and which shims/spacers, and how many do I need now, if they are thicker or thinner?
    I also note that the Gantry plates advertised in the shop, are different than the original shape. Are these the new ones also? Can you suggest, and name, what is in a complete set of plates for my future Ox. I need to pre-order!
    Can I not "pre-order" a couple of spacer blocks and wait for them to be in stock as well? :)
    Gray
  2. Mark Carew
    Hello Gray,
    I am thinking that this conversation is supposed to be part of a PM? I am not following the start of this.
    If you could please send it in the PM so that i can follow as I am easily confused as well ;)
    Mark
