I pressed Pause on Openbuilds Control while milling...
Discussion in 'OpenBuilds Bug Report' started by Mightymike, Oct 12, 2020.
  1. Mightymike
    Hello again,
    I pressed Pause while milling and after i resumed the spindle moved the cut 0.5cm to the left and continued the cut. is this a software error?
    i attached an image to see.
    thank you in advance.
  2. Rob Taylor
    Is it replicable? Probably hard to tell anything definitive without seeing the g-code around where it happened and a serial log of the period around the pause event.
    I pause quite often, so shouldn't be. But yeah, try replicating, get the exact pattern of events that causes a mishap
  4. Mightymike
    ok i will try that and write here again.
    i have another problem tell me peter if i have to make a new thread to help others as well.
    The problem: in the same cut as before, when the spindle "dives" for the fist pass it is drilling off the designed area, creating like a tear.
    i will attach a photo.
    thank you again!
  5. Mightymike
    Sorry, but what do you mean by replicable? (i'm brand new in the CNC world..)
    and i forgot to copy the code... next time i will do that... thank you
    Also need the gcode. Always include the gcode files for analysis
    Replicate = reliably reproduce the same error (in case it was a once off mishap instead)
  7. Mightymike
    Ok Peter. I will do that and post back.
    thank you again!
    another question... :D
    is it possible to turn on off the live position of the spindle? because after one update it doesnt show up.
    Troubleshooting tab > Application Diagnostics > Disable 3D Viewer Realtime Job Position Indicator should be what you are looking for
  9. Mightymike
    i cant believe i couldnt find it...
    thank you again.
