I need help converting a mendelmax.
Discussion in '3D printers' started by Fluxcore, Jun 9, 2015.
  1. Fluxcore
    Fluxcore New
    Hi all . I have a used mendelmax 1.5 I would like to convert in to a mendelmax 2 .Is it possable to do this with just printed parts ?
    Have any of you done this ?
    I am new at this and any help would be appreciated .
    Is there a better configuration to use these parts i have ?
    I do have access to a printer to make the printed parts i would need .
    Is PLA ok to make the parts i need ?
  2. DiggerJ
    DiggerJ Journeyman
    Are you looking to just make the transition to the linear slides, or something more. I can't find a reason to make that change alone. Maybe a size change, or a whole ubit conversion to better bearings/bushings, but not sure what exactly you want to change. Are you having problems with your Y axis?
