Today i received my materials for building my 3D printer. It was very well packed! - thumbs up!- (unfortunately had to pay $39 customs duty on top the $50 shipping) When trying the delrin nut block on the lead screw, it does fit, but it's very tight! By hand i can only twist the block on the screw until the screw is starting to come out on the other side. Then my hand starts losing grip on the screw and i can't get it any further. Do i have to wear the blocks in in some kind of way (run the blocks up and down using a drill), should i lubricate them right from the start? (and if so, with what?) Please help me out?
Hi Winand, They have been made tight and will loosen-up (bed-in) with use. Running them back and forward with a drill a few times (no lubrication necessary) will do the trick. Tweakie.
D*mn, spent over 10 minutes turning the blocks back and forth over the 1 meter lead screw.. They seem to loosen up just a tiny little bit, but i still can't turn them by hand? I don't want that all my stepper motors force goes into moving the block over the screw For my CNC router i used a polish stainless M10 screw with a delrin block made for it. That one was gliding like butter.. Any other tips?
@Rick2.0: The nut is the Openbuilds nut, the lead screw the Openbuilds lead screw. The nuts were ordered however at iprototype.nl a distributor of openbuilds material since the nuts were out of stock on the openbuildpartstore. I now have experimented with some lubrication, i used graphite lock lubricant spray. It's much better now! strange though that lubrication seems necessary. @dddman; Shipping was UPS from the USA to The Netherlands..
Interesting. I tend to prefer the V-Slot Acme Nut Plate as all the nut blocks I have received are so loose that if I hold them vertically, a 1m stick of TR8*8 will actually spin itself through under its own weight. It appears there are some serious quality control issued in the manufacture.
