How to set up Auto-Zero using CNC XPro and GRBL Panel?
Discussion in 'Controller Boards' started by jeffmorris, Apr 3, 2018.
  1. jeffmorris
    jeffmorris Journeyman
  2. Giarc
  3. jeffmorris
    I watched the video. The first line of code works but the second line of code doesn't work. I'm hearing-impaired and while the video has captioning, I may have missed his instructions between the lines of code. The touch plate is 19.25mm high. What should the second line of code be?
    First line of code: G38.2 Z-0.5 F10
    Second line of code: G92 Z19.25 or G92 Z-19.25
  4. Giarc
    For your 19.25 mm thick touchplate. After the bit touches the plate using your G38.2 Z-0.5 F10 commands, then the code should be G92 Z19.25.
