CNC X Pro V3 Tool measurement z-axis
Discussion in 'Controller Boards' started by Stephan Schmidl, Mar 5, 2017.
  1. Stephan Schmidl
    Hi folks,
    maybe someone could give me a hint, how to connect probe tool measurement the correct way.
    I found a method for v2 but that didnt work for v3.
    Greetings
    Stephan
  2. snokid
    snokid Journeyman
    Z-probe pin now accessible from screw terminal
    I did it the old way, as I have v2
    looks like there should be a screw terminal labeled z-probe...
    hope that helps.
    Bob
    Stephan Schmidl and Mark Carew like this.
  3. Stephan Schmidl
    Hi Bob, thank you for your reply...but ground pin should be the same, as at V2 ?
  4. snokid
    snokid Journeyman
    any ground on the board would work. could even use the ground coming from power supply.
    Bob
    Stephan Schmidl likes this.
  5. Stephan Schmidl
    Well, installed all cables right, but nothing happened!
    Do I have to "arm" that probe thing anyhow?
  6. snokid
    snokid Journeyman
    how are you trying to get it working?
    are you sending g38.2 my set up v2.
    hope that helps.
    Bob
  7. Stephan Schmidl
    Hi Bob, I will try that later on, thanks a lot for your reply.
