how to make a long axis
Discussion in 'General Talk' started by jfeeney, Sep 28, 2014.
  1. jfeeney
    jfeeney New
    I want to order my first parts. My first build is going to be a long single axis or I might order enough parts to turn it into a x-y axis.
    If I want my x-axis to be 3 meter (2 lengths of 1500mm 20x20) what bracket (and other hardware) do I use to connect them together?
    Also I am assuming that the double V wheel will run inside the rail. Is this correct?
  3. jfeeney
    jfeeney New
    Thanks Rick
    I would have guesed wrong because I had picked thesehttp://openbuildspartstore.com/2-hole-joining-strip-plate/
  4. DiggerJ
    DiggerJ Journeyman
    Use both. The double Tees for inside the rail slot, and thhe plates you mentioned on the outside of the V-slot, facing the inside of the rails (where neither the gantry plates or wheels ride.
