How Long?
Discussion in 'General Talk' started by GrayUK, Sep 1, 2018.
  1. GrayUK
    Just a simple question, for those who know the answer. :)
    If I have a plate, 10mm thick and no countersinks, and I want to attach it with bolts to some VSlot Rail, into 5mm T Nuts, how long would the ideal bolt be? :rolleyes:
    Thanks :thumbsup:
    15mm.
    The slots allow a maximum of 6mm extension below the surface of the V-slot and the nuts require a minimum of 4mm below the surface of the V-slot to get sufficient grip. (This can be dropped to 3mm though if you invert the tee nut.)
    GrayUK likes this.
  3. GrayUK
    I need sooo many! :eek:
    Thanks Rick :thumbsup:
