How do I calculate gt3 steps per inch
Discussion in 'CNC Mills/Routers' started by John H, Sep 22, 2014.
  1. John H
    John H New
    Can I assume that 1 revolution of my stepper motor will deliver 60 mm (3mm spacing of teeth x 20 teeth on wheel) of travel? Can anyone verify my assumption or give me the correct procedure for calculating this?
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Hi John,
    You are quite correct and teeth on wheel times pitch of matching belt is the way to calculate actual movement per one revolution.
    Tweakie.
