Hold downs
Discussion in 'General Talk' started by Robert-Lee, Dec 27, 2020.
  1. Robert-Lee
    I have the Lead 1515. Any suggestions for getting t- nuts or t-bolts (for hold-down clamps) into the track without disassembling the entire frame? Am I simply overlooking something here?
    Thanks everyone
  2. sharmstr
    Drop in t-nuts are available. They come in handy for sure. Drop In Tee Nuts
    I saw a guy on FB who drilled 3/8" holes on each end so he could slip in a bolt (not a traditional t-bolt).
    I mounted t-track directly to the extrusion using drop in t-nuts.
    What I like about both of those solutions and opposed to you wanting to use t-bolts is that you can remove the bolts when not in use.
    Robert-Lee and Rick 2.0 like this.
  3. Robert-Lee
    Great idea. Thank you!
  4. Robert Drisaldi
    Would you mind sending me a picture of your installed t-track, installed to the extrusion?
  5. sharmstr
    Of course. I'll do it once I get into the shop.
    Robert Drisaldi likes this.
  6. sharmstr
    Here you go.
    I used the drop in t-nuts linked above with these 8mm screws: Low Profile Screws M5 (10 Pack)
    You'll need to clearance the t-track a bit to fit the head of the screw in. I used a step drill for this.
    It doesnt need much clearance
    Then thread the drop in t-nuts and install
    There's not issue with the t-bolts hitting the head of the screws.
    PatrickNeff and Giarc like this.
