Hiyas . I am having no luck finding any tutorial videos for CAM .
Discussion in 'CAM' started by Brad Guest, Apr 9, 2021.
  1. Brad Guest
    All I can find is the "your first print HELLO WORLD " one . I want to see how to use everything. things like changing metric to imperial . Does anyone have a link to something like that ? I am also wondering if there is any free CNC Gcode software out there other than CAM ?
    No videos, its so simple you don't need one
    Open file. Select entities. Click Add to toolpath. Set parameters. Click Apply
    When you have all the toolpaths created, click Generate Gcode
    Just play around in it. All the buttons have tooltips, bottom status bar has tips, etc.
    No Imperial mode at this time
    Other CAMs: see docs.openbuilds.com > Software section
    Rick 2.0 likes this.
