High-Torque NEMA 23 Current
Discussion in 'General Electronics' started by mahty, Jan 30, 2022.
  1. mahty
    mahty New
    Hi Folks,
    I just purchased a number of linear actuators from OpenBuilds using the OpenBuilds high-torque NEMA 23 steppers. The current rating in the spec is a bit confusing. Is it truly 3A/phase, or 6A in total? This seems to be quite a lot for a stepper.
    They are 3A Motors, correct. :)
  3. mahty
    mahty New
    To clarify, being 3A/phase, do I need a controller that can handle 6A or 3A to drive one?
    #4 Peter Van Der Walt, Jan 31, 2022
  5. MS Holmquist
    On this same topic, can I expect the Blackbox to use 3A to drive any stepper that I plug into it?
    Basically yes. But also compare other motor specs to ours (inductance, coil voltage, resistance etc). Amperage is just one of the parameters to take into account
