hi gyus need a help with xpro and acro 1000x1000
Discussion in 'Laser Cutters' started by markiemark79, Apr 15, 2018.
  1. markiemark79
    hi i have a problem config xpro i tried estlcam did work but nothing was showed on gcode sender also laserGRBL and laserWeb.then i loaded via xloader grbl 1.1f hex file so what do i have to do to get that thing working?
    acro system 1000x1000
    xPRO v3 board
    power supply 12v 29A s-350-12
    nema 17 1.8'' steep
    laser diode will be
    JTechPhotonics - 2.8W Laser
    anyone here who can help me how to sort that thing out please
  2. markiemark79
    Don't know what to do and if settings is right
  3. markiemark79
    Also why those 4red lights shows up after I loaded hex file into it?
  4. Gary Caruso
    Did you program the xpro with estlcam or just make gcode and run it with gcode sender?
    if you programmed it you have to reprogram GRBL into it to use it with gcode sender again
  5. markiemark79
    Hi I did seems to be working but laser module will arrive tomorrow so am gonna put it all together and will let ya know
  6. markiemark79
    I run it straight away with estlcam but I reprogrammed with gcode sender so let c tomorrow
