Help with Z axis
Discussion in 'CNC Mills/Routers' started by Alberto Boria, Jul 12, 2015.
  1. Alberto Boria
    I need help configuring Z axis with the Gecko 540. The X and Y are working great but the Z axis motor not running just hard sound but do not move. I'm using an Acme 1/2-10 rod in the Z axis. Any help would be appreciated.
    Thanks,
    Alberto
  2. Joe Santarsiero
    Joe Santarsiero OB addict
    Is the coupling tightened while your trying to move the motor? If so, loosen it and try.
    Connect the y axis motor cable and try a move with the z motor. then try the z cable on the y motor to test the cable
  3. Alberto Boria
    Here a small video of what is doing when I try to jog.
  4. Joe Santarsiero
    I couldn't watch the .mov on my phone, but check to make sure your cable is made properly. step and direction might be wrong.
  5. Alberto Boria
    Thanks for the help I found I combine the cables wrong :banghead: that was the problem.
  6. Joe Santarsiero
    Your welcome. It happens.
