help with xpro v5 config
Discussion in 'CNC Mills/Routers' started by Smone, Dec 28, 2020.
  1. Smone
    Smone New
    hello everyone, im new to the cnc and looking for some help. i have the workbee 1510 belt driven cnc i belive the mechanial side is all ready, the issue is i have the xpro v5 controller but no software as yet. ive been on openbuilds site and downloaded openbuilds control v1.0.266 and followed the video to install and load the grbl settings but always getting the same message error (error: 3 grbl $ system command was not regognized or supported [$l=workbee 1510]. if anyone could help with were im going wrong would be brilliant thank you
    CONTROL only supports Grbl (github.com/gnea/grbl)
    $I is an official Grbl command: see gnea/grbl
    Seems their build of Grbl does not support the standard commands.
  3. Smone
    Smone New
    hi peter thank you for you reply, so am i using the wrong software. apologies for not really knowing alot yet thank you
  4. ljvb
    ljvb Well-Known
    You will have to use CNCjs or another GRBL sender. The OB software looks for a specific identifier within the $i command. The XPro v5 does not have that identifier, yet. I have a similar problem with the custom 6 pack I am using at the moment.
