Good afternoon/good everyone everyone, new to the world of CNC and trying to get things setup. Been attempting to run the surfacing wizard on a 1515 with no success. I have probed the material to set depths and boundaries (work area entered is pulled from the Open Builds site). I'm attempting to remove 1mm of material however each time I run the wizard the machine either cuts air or cuts way too deep into the material. Any help/suggestions is appreciated.
Any 3rd party components on the machine? or all from openbuildspartstore.com? Machine profile loaded from Grbl Setting tab? Did you run the Hello World to make sure its all set up?
Everything is open builds, no third party hardware, loaded settings from the GRBL tab. Only thing I haven't done is the hello world carve. I'll go ahead with that and see if it is successful.
