Help with my Z axis please
Discussion in 'OpenBuilds Forum Help' started by Mike Nieman, May 31, 2020.
Tags:
  1. Mike Nieman
    I am new and already surfaced my spoilboard. My next adventure is to put holes in my spoilboard. Before I do that I created just a one hole gcode to see how the hole would come out. But when I run it, the router drags on the spoilboard and does not lift up creating a channel in the particle board. I attached the gcode if anyone could please tell me what I am doing wrong. I am using Fusion 360 to generate the gcode for Openbuilds Control panel on my Workbee 1050.
    thanks
    Mike
  2. Alex Chambers
  3. Mike Nieman
    Alex, OpenbuildsGRBL within Fusion 360.
    Mike
  4. Mike Nieman
    The date on it is May 29 2020.
  5. Alex Chambers
    Hi @Mike Nieman, it's my bedtime here (UK), but I'll have a look tomorrow if no one else chips in.
  6. Mike Nieman
    Goodnight and thank you.
    Line 26:
    G53 G0 Z-10
    G53 = Machine coordinates: Either forgot to home Z (get switches, it helps) , or forgot to "fake the z home"
    Refer to f360/ob control and downward from there
    Alex Chambers likes this.
  8. Mike Nieman
    Thank You. It worked by putting Z to 0.
    Mike
  9. Mike Nieman
    I spoke too soon. My new problem is that the GCode does not lift the router bit after it drills my hole. Is there some setting in Fusion 360 to allow the router to lift out after a cut? Right now what it does is it drags through the wood at -12mm on its ways back to 0,0.
    That just sets Work coordinates; The fusion post uses Machine coordinates too:
