Help with Microstepping
Discussion in 'CNC Mills/Routers' started by propsGCC, Jun 21, 2018.
  1. propsGCC
    propsGCC New
    Hi everyone! Sorry if this is the wrong place to post, first time here.
    Right now, I've got a DQ542MA microstepping driver, hooked up to a NEMA23 motor. For the controller board, I've got an Arduino hooked up to Labview (sorry, project requirements). I'm currently just trying to achieve linear actuation with this setup. The one caveat is that I need the actuation to be smooth at low speed, hence microstepping.
    Setup (DQ542MA)
    PUL+(+5V) <----Arduino 5V
    PUL-(PUL) <----Arduino Pin 9 (PWM-capable)
    DIR+(+5V) <----Arduino 5V
    DIR-(DIR) <----Arduino Pin 8 (PWM-capable)
    Overview of code:
    DIR- is written hi or lo depending on desired direction.
    PUL- is being pulsed (hi then lo) for steps at a given rate. I figure all the PWM translation would be handled on the DQ542MA, so nothing fancy is going on here....
    Currently, I can get the thing to actuate just fine, but the thing is none of the microstepping options seem to work. I've flicked all the switches, but nothing seems to change.
    Am I wiring something wrong? How do I get this to microstep.
    Thanks!!
  2. Gary Caruso
    Hi Props, Make sure to do the dip switching with the power off, or at least power cycle the driver (power off for a few seconds for caps to dissipate) then try again.
    Another thing, is i'm not sure PWM is correct for signalling the driver, you want a fixed pulse length 10 micro sec and vary the frequency. PWM would vary the pulse width....
    cheers
    Gary
    #2 Gary Caruso, Jun 21, 2018
    Mark Carew and propsGCC like this.
  3. propsGCC
    propsGCC New
    Hi Gary,
    Combined with some code fixes of my spaghetti program, this saved the day!! Thanks a lot.
    Cheers!
  4. Gary Caruso
    Glad I could help!
