Help needed with breakout board
Discussion in 'CNC Mills/Routers' started by Saint Billy, Jan 29, 2017.
  1. Saint Billy
    I have recently purchased an HG08 breakout board which connects to a U300 motion controller to run my newly built Ox cnc.
    I am a woodworker and a little embarrased as my electrical knowledge is pathetic compared to a lot of you on here, hence my asking for help.
    The HG08 breakout board supports 5 axis, I have 4 nema stepper motors to connect to the board each of which has 4 wires, red, green, yellow, blue. On the breakout board each stepper motor input has GND, VCC, CKA-D, CWC, ENA-D.
    I do not have a clue what wire does what on the stepper motor nor do I know what goes to where on the breakout board. I know you can connect a voltage meter to the stepper motor or connect and pair stepper motor wires to check resistance but that still does not help me detemine where each wire goes as I do not understand CKA etc abbreviations on the breakout board.
    If someone knows what wire goes to what that would be a massive help.
    Also, on the controller boards I have seen there is a clone drive for the second Y axis stepper, presumerably on this it just goes into one of the spare A or B inputs as there is no clone?.
    Cheers in advance.
  2. Kevon Ritter
    Kevon Ritter Veteran
    A breakout board serves are a means of communication between your computer and your machine. A breakout sends signals to a separate unit called a driver. The driver is what controls the stepper. Each stepper has its own driver.
    Saint Billy likes this.
  3. Giarc
    You also need to figure out which wire is paired with which. Pick a wire. Hold one of the other three to that wire. Try to turn the motor. If it is extremely hard to turn, that is a pair. If not, pick another wire. The Ox build videos go through many of the intricacies of building a CNC to include finding wire pairs. If your motor turns the wrong way, pick one wire pair and reverse their hook-ups to the board.
  4. Saint Billy
    Well that clears that up, I have obviously overlooked that another bit of kit is needed, in fact 4 bits of kit, oh dear. Thanks for the spot Kevon.
    So what exactly is the advantage of having a setup that has a Motion control board, Breakout board and drivers verses something like the Xpro3 where everything is on one board?.
  5. Saint Billy
    Thanks Giarc,
    I am out of my comfort zone with electrics as you can tell and have spent so long building the Cnc that I have mentally hit the wall, and it now looks like I need additional bits but hey ho. I will take your advice thanks for the help.
  6. Darathy
    Darathy New
    Benefit is drivers(depends which you get) can power a more powerfull stepper motors compared to xpro and they might even run them smoother.
  7. Saint Billy
    Ahh ok, that makes sense, thanks.
  8. Rick 2.0
    ...and if you burn out a stand alone driver it's no big deal to replace. Not quite the case with built-in drivers.
  9. Saint Billy
    Good point Rick 2.0
