Help me. I want to build CNC with Nema 17
Discussion in 'CNC Mills/Routers' started by budi.r, Dec 14, 2018.
  1. budi.r
    budi.r New
    my english so bad. i use google translate.
    please help me
    I want to build a CNC machine with Nema 17 and Aluminum Extruder 2040. Can you give a reference on what model is for me. and also the drawing plate.
    thanks. apologize if there are inappropriate words.
    best regard
    budi
    Hard to answer without knowing what you intend to use it for and what size cutting area you need desire.
  3. budi.r
    budi.r New
    i wan use the cnc for carving/cutting for 3mm - 5mm wood thickness
    size is 300mm x 400mm
    thank you
  4. Rick 2.0
  5. budi.r
    budi.r New
