Help! I need a favor.
Discussion in 'CNC Mills/Routers' started by DiggerJ, Oct 2, 2014.
  1. DiggerJ
    DiggerJ Journeyman
    My OX is not finished, but is assembled, and I really don't want to take it apart.
    I need a pattern of one of the gantry plates.
    I need a plate exterior (no inner machining needed). It can be out of MDF, plastic, plywood, anything that I can use for a form to make a mold. I will be using this as a pattern for making the mold parts. 1/4" thick would be great.
    Anyone have anything laying around and feel like helping out?
    Thanks in advance.
    Digger
  2. DiggerJ
    DiggerJ Journeyman
    Well...I tried to print one out on paper to cut out on MDF, gut can't get the size to match my plates. Any ideaqs?
  3. Steve123
    Steve123 New
    Try printing your file using Inkscape or AI. Inkscape and AI will print at the correct dimensions as long as you print at 100%.
  4. DiggerJ
    DiggerJ Journeyman
    No luck. I have never had this much problem printing a file to make a patter. Very frustrating.
  5. Steve123
    Steve123 New
    Try using this pdf file.
  6. DiggerJ
    DiggerJ Journeyman
    As my ol' Grandpa would say:
    " Its like a sore peter...you can't beat it!"
    Works great! I can spray glue it to my MDF and cut it out to make my mold pattern.
    I gotta get details on how you did it sometime. I have converted a ton of stuff, but having no luck right now.
    THANK YOU
  7. Steve123
    Steve123 New
    You are welcome. Took all about a minute to do.
  8. DiggerJ
    DiggerJ Journeyman
    I'm sure I was overcomplicating it. I tried the skp the dxf, and neither seemed to work.
  9. GrayUK
    Good old Grandpa! :ROFL::ROFL:
    Gray
