Help,..Help.....Fine Tuning the xpro
Discussion in 'Controller Boards' started by ian carfagna, Nov 18, 2014.
  1. ian carfagna
    OK...Big question. I wired the xpro and got all the motors moving. I created a test gcode file from sketchup and made the cut area 3 inched by 3 inches. BUT, when i run it, the x and y's are moving like 20 inches...for some reason the motors dont know what an inch is. How to i set what each step's value is?
  2. Texflyboy
    Texflyboy New
    Ian,
    I had the same issues when I first tried cutting air with my OX. I finally found this in a post from spark-concepts on their forum. These settings will get you close. Pay particular attention to commands $100 $101 and $102. They are much different than the the GRBL default settings.
    (From spark-concepts.com forum.
    Thread title "Known working settings for GRBL on a standard Zeus kit"
    Hi guys,
    We have been pulling data from user to find a good "average" setting for the Zeus/Ox CNC kits. We plan on releasing a custom hex for upgrading GRBL shortly. In the meantime this is where we are with settings:
    $0=10 (step pulse, usec)
    $1=255 (step idle delay, msec)
    $2=0 (step port invert mask:00000000)
    $3=6 (dir port invert mask:00000110)
    $4=0 (step enable invert, bool)
    $5=0 (limit pins invert, bool)
    $6=0 (probe pin invert, bool)
    $10=3 (status report mask:00000011)
    $11=0.020 (junction deviation, mm)
    $12=0.002 (arc tolerance, mm)
    $13=0 (report inches, bool)
    $14=1 (auto start, bool)
    $20=0 (soft limits, bool)
    $21=1 (hard limits, bool) \\Change to 0 (zero) if you do not have limit switches/homing switches
    $22=1 (homing cycle, bool) \\ Change to 0 (zero) if you do not have limit switches/homing switches
    $23=3 (homing dir invert mask:00000011)
    $24=50.000 (homing feed, mm/min)
    $25=1200.000 (homing seek, mm/min)
    $26=250 (homing debounce, msec)
    $27=3.000 (homing pull-off, mm)
    $100=26.670 (x, step/mm)
    $101=26.670 (y, step/mm)
    $102=200.000 (z, step/mm)
    $110=7500.000 (x max rate, mm/min)
    $111=7500.000 (y max rate, mm/min)
    $112=1500.000 (z max rate, mm/min)
    $120=100.000 (x accel, mm/sec^2)
    $121=100.000 (y accel, mm/sec^2)
    $122=100.000 (z accel, mm/sec^2)
    $130=510.000 (x max travel, mm)
    $131=770.000 (y max travel, mm)
    $132=170.000 (z max travel, mm)
    Please remember to take things slow/safe for the first couple times until you get a feeling for the settings some of these are much greater than the default GRBL settings (like the accel settings).
    Kagon - check to make sure you have the "use aggressive preload strategy" check in the GRBL Controller settings - Another option is to try you good in Universal G Code Sender - not quite as fancy GUI but the preloading strategy seems to work better with GRBL 0.9g's planner.
  3. dcarlisle
    dcarlisle New
    texflyboy
    thanks for posting this it helped me out a lot I just built a ox and was messing with the settings got them all screwed up so it wouldn't move at all put in these settings now it moves z works fine but when I move x and y they chatter a lot tried adjusting current doesn't seem to make difference took of the belts that didn't make difference
    when I set $1 to 255 after steppers move the sit there and click I know Im missing something it has to be simple but I am a total newbie at cnc and can't figure it out any help would be appreciated
  4. Texflyboy
    Texflyboy New
    Check your microstep settings. You should have jumpers installed on positions 1 and 2 on each axis on the controller.
    #4 Texflyboy, Apr 5, 2015
  • About Us
    [email protected]
  • Follow us on Instagram
  • Like us on Facebook
    Donate to Open Source
