Help For My Printer!
Discussion in '3D printers' started by emir sahin, Mar 22, 2018.
  1. emir sahin
    Hello i want to make 3d printer (cherry 3d) with cnc shield but when i want to load code, i take error: board_ramps_14_efb what i need to write?
  2. evilc66
    evilc66 Journeyman
    Why would you want to use a CNC shield? It has no hardware to drive the extruder or bed heater or inputs for the thermistors. Sure, you could hack those features onto the shield, but a RAMPS board does all that for you.
    As for your error, I think you will need to provide more information, like what Arduino board you are using, version of firmware, etc...
  3. jhonsam
    jhonsam New
    USE RAMPS instead of using CNC shield, CNC is a thermistors device that provides heat which may damage your system... if still have an issue contact
    Fix HP Printer Error code messages
