Help adding a Z-axis to this existing XY Plane
Discussion in 'Other Builds' started by Michael Ronzetti, Jul 12, 2014.
  1. Michael Ronzetti
    Hi all.
    First off, I'd like to applaud this entire community and it's opensource builds. You've been a life-saver in recent months in working on my project. I'm trying to build a openlabtools-esque microscope, but with wireless support from raspberry pi. I want to have a fixed optical microscope up top, and a microscope stage that is able to move in the X - Y - Z planes.
    I like the idea of this build:
    http://www.openbuilds.com/builds/x-y-stage-hidden-acme-rod-example.66/
    but again, I have no idea how to add vertical control. Do i try another linear screw and 3 other steel rods, all attached to the top part of the xy stage? Any other ideas? Many thanks in advance!
    Mike
  2. GrayUK
    Hi Michael.
    I think I understand your question. Instead of using a threaded rod on the other axis, as in the z axis, have you considered the use of belt drive, plus steppers? It would be more flexible from a build, and size, point of view, and much cheaper.
    Gray
