Hdpe feeds speeds
Discussion in 'General Talk' started by stuart wallace, Dec 10, 2020.
  1. stuart wallace
    Howdy,
    I’m about to make something like this in hdpe. I’ll use this bit
    https://store.piersonworkholding.com/SmartVac-3-Gasket-Slot-Endmill_p_17.html
    My dw611 can’t go that slow. I’ll do some tests this weekend to accomplish the slots. I wanted to see if anyone already had good feeds and speeds for hdpe with the dw611. That endmill recommends full depth of cut at .1”
    Cheers!
    Stuart
  2. Giarc
    I use 18000 rpm at 2500 mm/min at a cut depth of 1/2 the diameter of the endmill. HDPE is one of my favorite things to cut because it is so easy. I like to use an endmill with two straight flutes, but a spiral up cut works as well.
    JustinTime and stuart wallace like this.
