Half inch spindle
Discussion in 'General Talk' started by Rink, Feb 27, 2021.
  1. Rink
    Rink Well-Known
    Good evening.
    Anyone using a spindle with half inch collet on a LEAD 1010? Should I want that or is it just complete overkill for hobby wood carving?
    thx, rink.
  2. JustinTime
    JustinTime Veteran
    If you are going to buy a spindle buy one with an ER11 Collet. If you have the 1/2" spindle already, use it but use it mostly with a 1/4" collet or smaller. The machine will be much happier with the smaller collet and may even send you a Christmas card every year as long as you have it. :)
  3. Rick 2.0
    Overkill. Aluminum framed machines are not stiff enough to get full use of it. But if you feel you must you'll want to double up the X-axis similar to the OpenBuilds LEAD CNC Machine 1515 (60" x 60") as a 1/2" spindle will roll a single beam axis.
  4. Rink
    Rink Well-Known
    That's good enough for me. Thanks for the info.
