GT3 Clearance question
Discussion in '3D printers' started by JP Scott, Jan 14, 2020.
  1. JP Scott
    JP Scott New
    Greetings,
    I have two items you to seek help. My skill with Autodesk Fusion 360 is limited at this time. So, I hope you help.
    1) I need to know the thickness of a mounting plate for a NEMA23 motor so that a GT3 pulley attached to the motor will have the same clearance as the idler pulley mounted on a 3mm plate on the C-Beam as shown in the attached pic. The diagram is showing a NEMA 23 attached to a plate of unknow thickness.
    2) what is the best and strongest attachment for a 40x40 box beam and a C-beam?
    Your assistance and comments are really appreciated,
    Have a great new decade!
    Jim
