GRBL Spindle Control Easy Driver
Discussion in '3D printers' started by AndrewG, Nov 19, 2016.
  1. AndrewG
    AndrewG New
    Nov 19, 2016
    Hi Open Builds community,
    I am building a 3d printer from scrap and am looking to use the spindle control within GRBL to drive an a4988 (Easy Driver) controller to run a stepper motor.
    I have un-commented USE_SPINDLE_DIR_AS_ENABLE_PIN in config.h and have experimented with different settings for SPINDLE_MAX_RPM.
    I have PIN 13 going to DIR and PIN 11 to STEP on the Driver.
    I am able to get the motor to make a high pitched noise by sending a M3 S100 command, if I disconnect PIN 11 the motor will run for a bit and then stop.
    I know I am missing something here and would be very grateful for some expertise, I have Googled as much as I can. I suspect I am getting muddle between output for the spindle and the input to the easy driver but admit am a bit of a newbie to this and now a bit stuck.
    Thanks for reading.
