Grbl panel
Discussion in 'Control Software' started by 25ksuburban990, Mar 12, 2018.
  1. 25ksuburban990
    hello where can i get or who has a working link to download the Grbl control panel software
    google 'grbl panel download' and it is the first link!
  3. 25ksuburban990
    I GOT GRBL CONTROL PANEL DOWNLOADED I AM RUNNING WINDOW 10, CANT GET COMPUTER TO TALK TO GRBL CONTROLER MUST BE MISSINS SOMETHING, CAN OPEN PANEL BUT THAT AS FAR AS IT WILL GO DRIVER ISSUE OR WHAT NEED HELP
  4. Gary Caruso
    Did you install the arduino drivers? what are you using arduino or xpro or something else? can you see it on device manager when you plug it in?
    Are you seeing an available com port from the dropdown in grbl panel? set the rate to 115200
  5. 25ksuburban990
    using xpro v3 not seeing any drop down on the pane;l rate is at 115200
  6. 25ksuburban990
    ok get working had to change usb cable thanks to all for the help
  7. 25ksuburban990
    I thought I had this grbl panel downloaded and working after I changed the usb cable but this panel looks nothing like the panels I have seen e posted elsewhere here in this forum, only thing the comes up is com3 & 115200 and the arrow keys to jog( they work) I get movement but thats it, I cant even load a file
