Grbl has not finished booting
Discussion in 'CNC Mills/Routers' started by andrew openshaw, Jun 25, 2017.
Tags:
  1. andrew openshaw
    Been going nowhere fast.
    Installed / uninstalled the drivers, rebooted and still can't clear the error message. Any suggestions greatly received.
    thanks
    Andrew
  2. Akash
    Akash New
    i'm stuck with the same issue. PLease let me know if you find the solution
  3. TassieDevil
    hi, just setting up for the first time and i'm stuck with the same problem
    Have you found the solution cheers pete sunday 24th sep
  4. David the swarfer
  5. TassieDevil
    thanks for the reply, i was getting in over my head in a new field. i stopped reloaded the adrino this time into libaries and not lib and it works fine.
    all motors work . tomorrow i have to sort out the wiring to the y axis stepper motors
    cheers pete
  6. Akash
    Akash New
    hey , for the time being I've found an alternative way. In my case The " GRBL PANEL" seems to be working till now (apart from a few usual hiccups) .
    About UGS , I'm still stuck. I'm guessing windows isn't installing the drivers properly. I need to check the driver installation again.
    Akash
