GRBL Error
Discussion in 'Laser Cutters' started by darrepac, Dec 17, 2020.
  1. darrepac
    darrepac New
    Hello
    I succesfully connected my laser to my blackbox, then focussed it.
    Then I loaded a test file (power profile) made by lightburn and Control makes me this error when I clicked on "check size"
    I not not find such gcode into my file (attached), so no idea where it comes from
    Any hint?
    thanks
    Where is that gcode from, it has way too many decimals :)
  3. darrepac
    darrepac New
    I generated it with lightburn... so it is a setting in lightburn maybe?
    Upload the gcode file please
  5. darrepac
    darrepac New
    What is strange is that I do not see it in the gcode file...
  6. darrepac
    darrepac New
    I did, in the first post
  7. darrepac
    darrepac New
    In case it fails previously, here it is again
    Sorry! I overlooked it :)
    Indeed it wasn't the gcode, sorry first guess was wrong.
    Found a bug, will fix right away and release as v1.0.266 - it should ask to update itself shortly
  9. darrepac
    darrepac New
    Eh eh thanks!
    Steveathome likes this.
  11. darrepac
    darrepac New
    So I checked my Control version and it is 1.0253.. isn’t update automatic? Can I trigger it in some way?
  12. Peter Van Der Walt
    You can grab the latest exe from the link I posted above, or software.openbuilds.com for force things along
  13. darrepac
    darrepac New
    Ok so no automatic update?
  14. Peter Van Der Walt
    Yes, it has auto update.
  15. darrepac
    darrepac New
    Hey
    Got an other error with an other file. This time it was during run time (the result is weird). (gcode attached, generated by lightburn))
  16. Peter Van Der Walt
  17. darrepac
    darrepac New
    oh indeed, I got a lot of disconnection...everytime I start the fan for example...will have to work on it!
  18. Peter Van Der Walt
    Sooner rather than later :) before it damages something permanently. Go over wiring too, quick intermittent shorts also cause disconnects (and long term damage)
