Grbl 1.1f limit switch question
Discussion in 'General Electronics' started by Rob Atha, Nov 6, 2018.
  1. Rob Atha
    Rob Atha New
    Hi all
    I’m after a bit of advice regarding limit switches, I’ve previously experimented with this on the Arduino Uno but gave up but now want to get back to it.
    I still have the pull up resistors in place so all is good there, but I’m trying to find out the easiest way to implement the limit switches and should I use N/O or N/C loops
    Any advice here would be very greatful
  2. DarkPenguin
    DarkPenguin Well-Known
    NC, I believe. That way if a wire gets pulled or breaks it will trip.
  3. CNCMD
    CNCMD Journeyman
    It's really your decision on the matter.
    NO = In the event that you have a wire/connection go bad the system will not trip, however, the next time you home, the broken axis will run wild and crash the cnc.
    NC = In the event that you have a wire/connection go bad the system will trip and the job will stop whether you wanted that or not.
    David the swarfer and MaryD like this.
  4. Rob Atha
    Rob Atha New
    Thanks very much for you advice all
  5. David the swarfer
    The GRBL wiki has a lot of info...
    gnea/grbl
