Gradus M1 Pro and the 0-10V output
Discussion in 'Controller Boards' started by DarkPenguin, Jun 29, 2018.
  1. DarkPenguin
    DarkPenguin Well-Known
    So, is this supposed to do something? Connecting it to a WS55-180 BLDC driver to a spindle without a hall sensor. I can't get the spindle to, um, spin using this. I have to go back to the potentiometer control.
    I might buy another spindle and try with that.
    To determine if its the Gradus or the Spindle, measure the output voltage on the 0-10v terminal while sending M3 Sxxx commands, where xxx = 0-255 for Grbl 0.8, 0.9 and 0-1000 for Grbl 1.1
  3. DarkPenguin
    Thanks! I'll give that a shot. It was 10v when I measured it before. Didn't check how it moved, tho.
